[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4739: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3845) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4741: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3845) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4742: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3845) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4743: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3845) Форум рыболовного клуба "МАЯК" • Просмотр темы - Эхолот
Просто экран почти ничего не кушает. Лучи съедают энергию. И чем больше глубина, тем сильнее бьёт луч (там автоматическая подстройка глубины есть), тем быстрее сядет батарея. А еще в датчике установлен градусник, который температуру воды определяет. Тоже маленько кушает. В общем, не показательный у тебя эксперимент получился.
Так же, как и Евгений, приспособил для эхолота пластиковый ящик. Добавил вход для питания от мотора. Оставил отсек для блока зарядки (от старого бесперебойника) и второго аккумулятора.
Здравствуйте! Подскажите или проконсультируйте какой эхолот взять? Рыбалка на малом море, на моторной лодке на щуку, хочу приобрести его для поиска рыбы. Склоняюсь к модели которую рекомендует "Вождь" Humminbird, очень много хорошего слышал про данную модель, говорят аппарат стоит своих денег, но не понятно как он себя поведет на малом море , подскажите может кто юзал его на малом, я в них полный 0. Заранее спасибо!
Я не спец в тубусных эхолотах, но хотим его подарить на д.р. другу. Модель Humminbird Fishin Buddy 110x адекватная? В какой ценовой категории его смотреть? 4 градации серого, подсветки большой экран, в общем, с вижу он хороший.
Уже не первый год пользуюсь таким "приборчиком". Плюсы: компактность, оперативность. На зимней рыбалке всегда за пазухой, т.е. аккумуляторы в тепле, без проблем можно переходить от лунки к лунке при необходимости. Информативность устраивает, ценник, естественно, тоже. Приобретался за 1500 т.р.
комплектность
сам эхолот
Добрый день! Господа, подскажите за "Эхолот портативный JJ-Connect Fisherman 200 Ice Edition mark II" в основном зимняя рыбалка, ну и омуля иногда поискать...
